Overview
All these features require a Battery Toolbox License.The Otii Battery Toolbox is a software license that extends the capabilities of the Otii Product Suite to enable battery profiling, battery life estimation, battery simulation, battery testing and validation for low-power IoT devices and electronics.
The Otii Battery Toolbox license is:
- Associated with a user, not a specific piece of hardware.
- Sharable; a user can share it with another user, but it can only be used by one user at a time.
Using Otii Automation Toolbox, you can also configure a license pool that automatically shares the licenses among your battery evaluations setups. When using a shared pool, your test scripts can be configured to wait for a license to become available before execution.
Read more about each Battery Toolbox feature here:
Battery model parameters
| Battery model parameter | Otii Arc Pro | Otii Ace Pro |
| Points in Emulation | as many as no of iterations | as many as no of iterations |
| ESR Range15 | up to 5 kohm | up to 5 kohm |
| ESR Resolution | down to 1 mohm | down to 1 mohm |
| Voc Range | 0.5 V to 5 V | 0 V to 25 V |
| Voc Resolution | 1 mV | 1 mV |
| Capacity Range | no limit | no limit |
| Capacity Resolution | 1 µAh | 1 µAh |
